A
AC Question
I have a Motorola Droid Ultra and had been using FoxFi for wireless tethering as I have unlimited data. I accidentally downloaded the new OTA. I did not want to accept and install as FoxFi says it will not work beyond KitKat 4,4. I just kept delaying the install.
I found Sunshine and they stated if I installed Sunshine and unlocked my phone, before installing the OTA, I should be ok. I installed sunshine (s-off) and unlocked the phone. (That was very easy, even for someone with no experience.) I then finally installed/accepted the ota. Once the OTA was installed, FoxFi no longer works. What do I need to do now to use FoxFi?? Thank you in advance.
