1. Udbaro's Avatar
    My sd card gets unmounted n remounted simultaneously again n again.
    Very iritatng. Class 10 16 gb sd card .
    Asus zen2 4gb ram phone .
    Any soln /?
    09-30-2015 03:49 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! The card might be bad. Does it work on other devices normally? Do other SD cards work ok on your phone?
    10-01-2015 12:28 AM
  3. michaelkenney's Avatar
    I have the same problem (Blu Studio 5.0C HD). My phone is constantly unmounting and asking to remount the SD card, with a notification chime every time.
    (This phone chimes at me so much I often miss texts, as I'm so used to ignoring it for notifying me of nothing so often. I went through and turned off every notification I could find. It would be so nice is there was a general 'turn off all notifications' except for text.)
    I tried another SD card; same thing. I'm not going to buy another just to find out it's doing the same thing, as I suspect it will.
    It has done it twice while I wrote this.
    10-04-2015 01:28 AM
  4. B. Diddy's Avatar
    Welcome to Android Central! If it happens with any SD card, then I would suspect a faulty SD slot in the phone.
    Laura Knotek likes this.
    10-04-2015 01:57 AM
  5. michaelkenney's Avatar
    I just took it out. I'm not a power user, anyway.
    B. Diddy likes this.
    10-04-2015 03:05 AM
  1. Note 5 Bluetooth Stutter / Skip Problem with Playing Audio in Car
    By delfinparis in forum Samsung Galaxy Note 5
    Last Post: 10-24-2015, 02:51 AM
  2. Lock screen problem S6 edge 5.1.1
    By Vman2315 in forum Samsung Galaxy S6 edge
    Last Post: 10-01-2015, 11:30 AM
  3. Replies: 2
    Last Post: 09-30-2015, 03:32 PM
  4. Why can't my Xperia Z1 transfer files to my sd card?
    By AC Question in forum Sony Xperia Z1
    Last Post: 09-30-2015, 02:27 PM
  5. LG G4 Problems with Notifications
    Last Post: 09-30-2015, 01:16 PM
