1. AC Question's Avatar
    I've deduced that it's either software or the usb port of the phone.
    I plug it in and it shows the lightning bolt but just stays there.
    A few times last night (twice) it would finally move from the lightning bolt to showing the percentages, however, it definitely stopped as it got to 5%. The first time, I didn't know what happened it just didnt charge. The next time I specifically watched it, made sure it was untouched and once it got to 5% it just stopped.
    I have tried to turn it on multiple times to charge it and it usually fluctuate between 2 and 4% dying quickly, however, a few times I would insert the charger it would immediately say charging and then just stop to not charging. I tried to insert the cord at different angles and strengths to no avail. Once it was at 5% and it would do the same thing.
    I tried to insert it into a computer and it was the same bolt. I tried different outlets, different walls and different chargers.
    I've had this happen before, I would have to take it out of my case and it would charge for a second. I previously thought it was something very bad, however, the next day it ended up randomly charging.
    I'm not sure whether the problem is hardware or software, because I would believe if it were hardware, the lightning bolt wouldn't show up on the phone at all; it is apparently registering on the phone. Maybe there's no charge or maybe the phone has a mechanism stopping it from charging. Oh yea, I wiped cache partition too.
    10-01-2015 12:26 PM
  1. Samsung galaxy s6 edge 64gb verizon
    By StayFly in forum Marketplace Archive
    Last Post: 11-19-2015, 04:07 PM
  2. My S6 Edge Plus randomly went into a black and white mode, how do I fix it?
    By AC Question in forum Samsung Galaxy S6 edge+
    Last Post: 10-01-2015, 10:29 PM
  3. will using the Samsung fast charging car charger cause the phone to overheat?
    By KiwiCoalBattery in forum Samsung Galaxy Note 5
    Last Post: 10-01-2015, 03:07 PM
  4. Email txt contact wont use custom contact message tone note 4
    Last Post: 10-01-2015, 10:59 AM
