1. AC Question's Avatar
    Hi all, I just bought a Powerbear battery and it charged from 60% to 100% in about 30 minutes (suspicious!) and then dropped 10 in 5 minutes and predicts that the battery will be exhausted in 2 hours. Is this something to do with it being new? Is there something I should do or have I got a dud battery?
    Thanks for any help!
    Phil
    10-01-2015 03:00 PM
  2. belodion's Avatar
    That sounds bad to me.
    10-01-2015 09:19 PM
  3. Kavan Sidhu's Avatar
    Sounds suspicious to me. My friend sold me a galaxy S4 and its the same thing with all 3 original oem batterys. Last 2 hours at the most. Was going to try a powerbear battery. But am scared now and will try the anker instead.
    Edit:
    Decided to try this instead.
    http://www.amazon.com/Hyperion-Micro...cUvbUpU4731085
    Description says google wallet nfc added so it all good. Order just placed.
    10-05-2015 05:24 PM
  4. Miller6386's Avatar
    I bought a powerboat extended case for my S5 when I had it and it did not work at all.
    Anker on the other hand have been phenomenal! !!!
    Note 4tified
    10-05-2015 05:31 PM
  1. Strange issue with WiFi on Galaxy S4 -- Please help
    By ELandau in forum Samsung Galaxy S4
    Last Post: 10-28-2015, 02:18 AM
  2. Replies: 3
    Last Post: 10-02-2015, 05:31 PM
  3. Replies: 2
    Last Post: 10-01-2015, 02:56 PM
  4. Why is there a problem with Google Play Srevices
    By TheSykO in forum Ask a Question
    Last Post: 10-01-2015, 02:09 PM
  5. Replies: 0
    Last Post: 10-01-2015, 02:05 PM
