1. Elma van Zyl1's Avatar
    I bought myself a tuff luv qi enabled wireless charger to charge my Cat S50. Last night, phone is on 55% so I decide to try my new charge . Put phone on pad, positioned it so the blue light starts flashing, phone displays 'charging 55%' it makes a noise and then apparently stops charging for a sec, then boink noise and it displays 'charging55%' again. And that was the story for the rest of the night. It never went past 55% . Am I doing something wrong? Is there something wrong with my charger?
    10-03-2015 12:28 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Is the phone in a case? If so how thick is the case? Try charging without a case, if it's present.
    10-03-2015 10:09 PM
  3. Elma van Zyl1's Avatar
    Appears the adapter I used was the problem. Charger only comes with a USB cable. Tried plugging it into laptops USB. Worked like a charm. Tried all my USB power adapters. The iPads adapter does the job. Charger and phone heat up significantly, but I understand that's not uncommon.
    B. Diddy likes this.
    10-04-2015 07:20 AM
  1. Replies: 2
    Last Post: 10-12-2015, 10:08 AM
  2. Google Now and Microphone not working?
    Last Post: 10-03-2015, 10:24 PM
  3. Note Pro 12.2 wont turn on, not rooted
    Last Post: 10-03-2015, 10:12 PM
  4. Phone is not recording sound?
    Last Post: 10-03-2015, 10:42 AM
  5. My android one is not getting on..Please help!!
    Last Post: 10-03-2015, 10:38 AM
