1. AC Question's Avatar
    Android 5.1.1, kernel version 3.4.0-g0315133. When I try to connect to my Windows 8.1 laptop via usb my Nexus 5 keeps connecting and disconnecting every couple of seconds. It's set to MTP, shows up as 'Nexus 5' in explorer. I've reinstalled drivers and used several cables. Nothing works!
    10-03-2015 03:09 PM
  2. Laura Knotek's Avatar
    Open device manager. Go to USB root hubs. Make sure that "Allow the computer to turn off this device to save power" is not checked.
    Sent from my rooted Nexus 7 (2013) using Tapatalk
    DarksideDave69 likes this.
    10-03-2015 03:16 PM
  3. DarksideDave69's Avatar
    Hi Laura,
    Thanks for the reply. Unfortunately it didn't work.
    10-03-2015 03:27 PM
  4. Laura Knotek's Avatar
    Are you using a USB 3.0 or 2.0 port? Id suggest trying USB 2.0, rather than USB 3.0.
    10-03-2015 03:32 PM
  5. DarksideDave69's Avatar
    I'm using a new Dell XPS15 which I assume has USB3 ports. My old laptop (XPS15 L501x) doesn't work any more.
    10-03-2015 03:35 PM
  1. Why is Airplane mode stuck on turning off?
    Last Post: 02-15-2016, 01:41 AM
  2. How do I find my SD card?
    Last Post: 10-03-2015, 09:13 PM
  3. How do I receive pictures on my LGl22c?
    Last Post: 10-03-2015, 09:10 PM
  4. Replies: 1
    Last Post: 10-03-2015, 04:11 PM
