1. AC Question's Avatar
    Is the 3000 mAh battery bigger than the 2100 mAh? Will it fit in my Samsung Galaxy SIII phone? Will it produce more heat than the standard?
    10-06-2015 03:34 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! If it's an extended battery designed for your phone, it should also come with a replacement back cover that accommodates the size. Larger batteries shouldn't generate more heat.
    10-06-2015 08:30 PM
  1. My Samsung just went deleted everything on my phone how do I fix?
    By Danielle Lucz in forum Samsung Galaxy S6
    Last Post: 10-19-2015, 11:49 AM
  2. Nexus 5X vs. Lumia 950
    By Tadrift in forum Phone Wars
    Last Post: 10-13-2015, 12:37 PM
  3. How to interpret Antutu Tester battery test score?
    By AC Question in forum Moto G (2015)
    Last Post: 10-10-2015, 10:17 PM
  4. Why don't I get LTE on my Note 5 Duos on T Mobile?
    Last Post: 10-06-2015, 03:38 PM
