1. AC Question's Avatar
    I have a Samsung S3. My alarm is set on ´repeat every day´ and I have accidentally left it at home. I am supposed to be going away tonight and am wondering if it will just keep on ringing and ringing until the battery runs out (annoying the neighbours) or if it will stop after say 5 minutes?
    10-07-2015 10:37 AM
  2. the tall guy's Avatar
    Hi, from experience it will ring for a minute then stop, it won't keep repeating itself all day. It will only repeat at a specific time each day for about a minute then stop.
    10-08-2015 02:49 AM
  1. How do i fix the missing bitmap stage
    Last Post: 02-08-2017, 04:36 PM
  2. How do you fix unfortunately measure has stopped on Android
    Last Post: 10-21-2015, 07:50 AM
  3. Replies: 3
    Last Post: 10-14-2015, 06:25 AM
  4. Replies: 2
    Last Post: 10-08-2015, 11:40 AM
  5. Does lenovo tablets need sim card before it work
    Last Post: 10-07-2015, 09:53 AM
