1. AC Question's Avatar
    I just want to know why on some occasions when i listen to a song it is mediocre quality, but on other occasions when i listen to the same song it is astonishing sound quality.
    Here is an example of what happens: I tap on a song to listen to it, and the sound quality is sub-par. Then i tap the 'skip' button, which skips to the end of the song and re-plays it. Occasionally, the song replays and it is even better quality, so what i tend to do now is when i want to listen to a song i select it and then replay it about 5-10 times until it starts playing at a good sound quality.
    It's not the headphones, as i have experimented with a few pairs. I just want to find out if there's a fix so that my songs are crystal clear quality 100% of the time so i don't have to restart them 10 times until i get a good quality.
    10-07-2015 05:44 PM
  2. Monitordroid's Avatar
    Are you streaming the music off the internet or do you have it downloaded? If you are streaming it, the quality depends on how good your internet is.
    B. Diddy likes this.
    10-07-2015 11:01 PM
  3. Chakaii's Avatar
    They are downloaded onto my phone. The quality doesn't fluctuate whilst I'm in the middle of a song, it stays consistent.
    10-08-2015 05:32 AM
  1. Anyone have the UHD toshiba chromebook?
    By Steve Adams in forum Toshiba Chromebooks
    Last Post: 01-01-2016, 06:57 AM
  2. Why can people on speakerphone,hear my Youtube clips,and text tones?
    By Samson2005 in forum Samsung Galaxy S6 edge+
    Last Post: 11-02-2015, 07:27 AM
  3. Replies: 1
    Last Post: 10-08-2015, 12:21 AM
  4. My contact number no came after sofware update at my s4
    Last Post: 10-08-2015, 12:20 AM
