1. AC Question's Avatar
    I have a Samsung Galaxy Note 3 Sm-n900A. Recently the charger port stopped working and I needed to replace it. I ordered a new port for a N900a. When I went to remove the old port it said N900P on it and looks slightly different then the new N900a port. I tried installing the N900a port but am having some compatibility issues-it won't charge and shuts off after non use for a few minutes (The phone will work when turned on). I was wondering if I just have a bad n900a port or if I need a n900p port to replace what the old one even though it is a N900A model phone? ATT is my carrier.
    Are the n900a and n900p charger ports interchangeable? Will a reset of the phone fix this problem? Any insight you can provide would be greatly appreciated.
    Thanks.
    10-09-2015 08:51 AM
  1. Change EDGE to LTE
    By Bob Schofield in forum Ask a Question
    Last Post: 10-13-2015, 11:06 AM
  2. Replies: 1
    Last Post: 10-09-2015, 03:26 PM
  3. Note 5 battery draining fast
    By Muhammad Tayyab Iftikhar in forum Samsung Galaxy Note 5
    Last Post: 10-09-2015, 07:52 AM
  4. Hello HTC max, got rid of my note 4
    By PublicImageLtd in forum HTC One Max
    Last Post: 10-09-2015, 06:56 AM
  5. Should i upgrade to note 4 or 5?
    Last Post: 10-09-2015, 05:11 AM
