1. AC Question's Avatar
    I have a Galaxy S6, in my office the internet connection is super unstable. My phone spends all day connecting and disconnecting from the internet. It also gets super hot (I'm not sure where to see how hot it actually is) a couple times I've been worried and just turned it off and rebooted it in safe mode. This works for safe mode but I eventually would like to use some other apps. Is there anything I can do other than turn my phone off during the time I'm at work?
    10-12-2015 02:01 PM
  2. Rukbat's Avatar
    If the problem doesn't appear in safe mode, it's being caused by some installed app. You'll have to turn them off one at a time, or disable them all and enable them one t a time, to determine which one is causing it.
    10-12-2015 06:04 PM
  1. Samsung S6 Aux/media volume level won't stay in max
    Last Post: 10-12-2015, 03:11 PM
  2. Replies: 1
    Last Post: 10-12-2015, 02:08 PM
  3. Replies: 1
    Last Post: 10-12-2015, 02:05 PM
  4. Where/what is the TAB ICON, and how do I close TABS?
    By AC Question in forum Android 5.0 Lollipop
    Last Post: 10-12-2015, 01:28 PM
