1. AC Question's Avatar
    Yesterday i was playing a game (asphalt 8) on my LG G Stylo from metro pcs when it suddenly froze and my phone turned off and went into a boot loop. after an hour or two i had no choice but to hard reset the phone. After the hard reset i noticed the phone had no sound even though the volume was raised to the highest. The audio jack also doesnt detect anything plugged in. The worst problem occurs when i lower the volume to 0 the device crashes and then freezes and even after taking the battery out and powering back on, the device simply fails to operate to the extent it is unusable unless i hard reset it again. Any solutions or ideas on what might be the problem???
    10-15-2015 08:31 PM
  2. zimlokks's Avatar
    If everything is stock and youre not rooted, it might be a faulty device.
    10-18-2015 12:55 AM
  1. Replies: 1
    Last Post: 10-16-2015, 07:03 AM
  2. why is my lg earphones volume does not work?
    Last Post: 10-15-2015, 08:23 PM
  3. Replies: 0
    Last Post: 10-15-2015, 08:07 PM
  4. Replies: 0
    Last Post: 10-15-2015, 08:00 PM
  5. Replies: 0
    Last Post: 10-15-2015, 07:45 PM
