1. AC Question's Avatar
    Phone always starts heating gradually when calling for more than 5 mins, at 15 mins call its more like you can't resist it at your ear lobe. I checked with cpu-z app my phone's frequency is 768-1200. Since minimum frequency is 768 may be its happening.
    But I am not sure.
    But I used set-cpu and all apps its minimum frequency is 768 only, I can increase but can't decrease.
    Other wise it heats only when I use data or wifi, or more no of apps at a time.
    I used the app TalkIntact to stop wifi, auto sych, data during call but Still the same issue found.
    Thats managable, but heating during call means I can't talk. Please provide some solution if you know.
    10-16-2015 02:20 AM
  2. belodion's Avatar
    Welcome.
    Is your signal poor?
    It may also be worth having your SIM tested.
    Otherwise, the device may be faulty. Contact the manufacturer's support team.
    10-16-2015 05:03 AM
  1. Replies: 1
    Last Post: 11-11-2015, 03:13 AM
  2. Replies: 1
    Last Post: 10-16-2015, 06:52 AM
  3. How do I unlock my Android?
    Last Post: 10-16-2015, 05:05 AM
  4. How unlock honor 4c with mi band?
    By Marsel Sharipov in forum Honor 4X
    Last Post: 10-16-2015, 01:39 AM
  5. Replies: 0
    Last Post: 10-16-2015, 01:28 AM
