03-10-2017 01:14 AM
41 12
tools Reply
  1. Givenator 5's Avatar
    My phone mobicel and is in no command mode, when i try to hard reset it it still says no command after the completion of the formatting and it also says, it needs a security code which i forgot.
    Please Help
    09-28-2016 03:00 AM
  2. anon(632115)'s Avatar
    Do you mean the Google password? Check this out [GUIDE] Forgot Password? Read Here!
    09-28-2016 05:20 AM
  3. saadabbasi535's Avatar
    How to unlock icloud for android
    How to install software in mobile
    09-29-2016 12:12 AM
  4. B. Diddy's Avatar
    Welcome to Android Central! Sorry, but does this have anything to do with the original post of this thread? If not, then please create a new thread with your question. Thanks!
    09-29-2016 12:54 AM
  5. jeffhaskins's Avatar
    If it is a Straight Talk branded LG phone it is like that because Straight Talk doesn't want you to be able to use the recovery except for factory reset from settings app. I have an l34c and an l15g that were both like this with the stock recovery.
    09-29-2016 01:11 AM
  6. fleischerj123's Avatar
    Starting I have rooted my phone with the help of king root app. This app has bricked my mobile. Then I have open the custom recovery it is only showing only "No command" and also not showing the options such as reset, reboot,install and other options what I have to do please help me I want to root my phone, if my custom recovery will get back doesn't show the "No command" please help me I will give plenty of thanks please
    I don't know what phone you have. But same thing just happened to me yesterday. Took me like 12 hours to figure it out but I had to search online for my specific model phone and download a recovery file ...a new kernel file...and then another file that was the stock firmware for my specific device...then had to use Odin to install. Not specific sorry but to sum it up that's what I did
    10-23-2016 11:51 AM
  7. fleischerj123's Avatar
    10-23-2016 01:02 PM
  8. Oscar90916's Avatar
    I have this same issue with a s7 do I wait til it dies? it wont let shut down with the power button and volume down
    11-03-2016 02:11 AM
  9. damion moxam's Avatar
    Worked for me
    12-25-2016 05:38 PM
  10. Raymeel Dexter El's Avatar
    My LG model: LS675 won't work. I went into recovery mode and i have done everything i could but it still says "no command. " this started after my little brother rooted my LG. Please help
    01-01-2017 03:48 AM
  11. jeffhaskins's Avatar
    Are you saying recovery worked until he rooted it? Just about all newer LG phones have this no command in their recovery, it has nothing to do with root. Root is just a binary file in /system/bin or /system/xbin.
    01-01-2017 09:55 AM
  12. murph673's Avatar
    Hi Anthony - did you ever get an answer on this? Same thing just happened to my girlfriends Droid Turbo and she cannot get it to reboot and it seems like we have lost the last 2.5 years of pictures. Please let me know. Thanks.
    01-06-2017 01:47 PM
  13. murph673's Avatar
    Hi - did you ever get an answer on this? Same thing just happened to my girlfriends Droid Turbo and she cannot get it to reboot and it seems like we have lost the last 2.5 years of pictures. Please let me know. Thanks.
    01-06-2017 01:50 PM
  14. Destiny Hucks's Avatar
    After you have done the wipe cache partition, whats next? I did as you said and it said at the bottom of the screen that the cache wipe was complete. It is still on that menu screen though. Do I do it again or choice another option (such as power off or reboot system now?)
    01-12-2017 08:19 AM
  15. belodion's Avatar
    Welcome.
    Select Reboot Now.
    If you still have problems, let us know.
    Sent from mTalk
    01-12-2017 02:12 PM
  16. hareshsk's Avatar
    Superb solution, worked for me. Saved lots of time and efforts for me...thank you...
    belodion likes this.
    03-10-2017 01:14 AM
41 12
  1. Why am not able to swipe to next image?
    Last Post: 10-16-2015, 05:18 AM
  2. Notes app with sync and pin to status bar functionality
    Last Post: 10-16-2015, 04:56 AM
  3. Replies: 0
    Last Post: 10-16-2015, 04:35 AM
  4. Is there a way to set up muti touch without rooting note4?
    Last Post: 10-16-2015, 04:24 AM
  5. Why I am not able to use the OTG feature in my HTC Desire 610?
    By HTCDesiree610 in forum Ask a Question
    Last Post: 10-16-2015, 04:21 AM
