1. AC Question's Avatar
    I recently upgraded to an S5 from an S3. I listen to music on my SD card on my phone when in the car and on my S3 I had the bluetooth volume set at max and it stayed that way, but on my S5 I have to keep turning up the volume on the phone to get the same volume. I do not want to turn the car stereo up louder because if I were to switch between sources like the radio it would be extremely loud. By placing my phone's bluetooth volume up to max it is at the same level as any other source on my car stereo.
    Please note that I already have it set to max on the phone itself but as soon as I connect to my car the media volume is set lower. Interestingly enough when I turn it up on the phone the added volume on the volume indicator is orange instead of the normal light blue.
    10-18-2015 10:58 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Are you using the stock Music app? If so, go to its settings, and turn on Smart Volume. Does that make a difference?
    10-18-2015 02:36 PM
  1. Replies: 1
    Last Post: 11-25-2015, 10:17 AM
  2. Can an app spy on me
    Last Post: 10-19-2015, 07:39 PM
  3. Why is my phone acting up?
    Last Post: 10-18-2015, 02:39 PM
  4. Replies: 1
    Last Post: 10-18-2015, 02:37 PM
  5. Can you guys fix the screen on my driod turbo??
    By Hunter2015 in forum Ask a Question
    Last Post: 10-18-2015, 11:26 AM
