1. AC Question's Avatar
    Hi, I had my Samsung Galaxy Tab Pro 8.4 16gb for almost a year now. Recently I have been experience this problem that I believe is relate to the sd card. I cannot install any app from any source. Also whenever I move files from device storage to the card, or any action that does changes to the card, the device would just lag and the application that is doing the action would be dead. And then the card would become unreadable, although it's still show as mount to the device. Anyone might know the reason to this and how to fix it?
    P.S. I have try factory reset and it didn't make a difference, old apps can be install, but not any new apps.
    10-18-2015 11:35 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! SD cards can fail. They can also be defective, or be counterfeit as well. Try a different card--does the same problem persist?
    10-19-2015 01:40 AM
  1. Lock Screen Pin Code Problem
    By juwster in forum HTC One M8
    Last Post: 12-21-2015, 03:02 PM
  2. How do I move everything possible on my phone to my SD Card?
    Last Post: 10-19-2015, 05:15 AM
  3. Problems with phone and sd-card slot
    By Pandagurl64 in forum General Help and How To
    Last Post: 10-19-2015, 01:54 AM
  4. droid Turbo Overheating problem
    By NateMkII in forum Motorola Droid Turbo
    Last Post: 10-19-2015, 01:52 AM
  5. Replies: 1
    Last Post: 10-18-2015, 07:01 PM
