1. AC Question's Avatar
    I bought a Samsung galaxy a3 and like it. But the problem is, I turned on auto recieve mms but I still need to turn on data in order to download mms messages.
    Is this just a samsung touchwiz problem or is there a solution? I have tried to look over my apn but seems alright with the settings and tried making one called mms only, nothing worked.
    10-19-2015 11:57 AM
  2. the tall guy's Avatar
    Hi, you need to have data enabled in order to receive an MMS, so your carrier can charge you.
    12-18-2015 04:14 AM
  3. AlphaTango414's Avatar
    You have to have mobile data enabled to receive MMS. Auto fetch doesn't work if you have you have mobile data disabled.
    This is carrier / android not Samsung or TW.
    12-18-2015 04:26 AM
  1. Xperia M4 Aqua not connecting to PC
    Last Post: 09-12-2016, 12:25 AM
  2. How similar apps section works in Google play store?
    By Avinash UrbanPro in forum Google Play Store
    Last Post: 07-31-2016, 04:56 PM
  3. Why my devices not working on wifi?
    Last Post: 10-19-2015, 12:00 PM
  4. Verizon Galaxy s6 to work on Tmobile - Help
    By dkp23 in forum Samsung Galaxy S6
    Last Post: 10-19-2015, 11:17 AM
