1. AC Question's Avatar
    On my Galaxy S3, I could add to my reject list numbers starting with "XXX" so that I could block areas rather than type in the whole number.
    However, on my S5 Neo, I can not find where I can set a matching criteria (as it was on the S3) - it just seems you can only block individual numbers.
    Any ideas anyone ?? I have found some marketing companies have bought blocks of numbers, and so if I could block/ reject numbers using "starting with XXX" then I could block the whole lot and not just one number.
    Any help will be gratefully received :-)
    10-19-2015 03:23 PM
  1. Can this be fixed without doing a whole system reboot
    Last Post: 12-18-2015, 04:44 AM
  2. Colors on phone are too blue how do I fix it?
    By AC Question in forum Displays
    Last Post: 10-19-2015, 04:13 PM
  3. VoLTE Security Vulnerability on Note 4, Other Android Devices
    By amitmalhotradc in forum Samsung Galaxy Note 4
    Last Post: 10-19-2015, 04:09 PM
  4. Replies: 0
    Last Post: 10-19-2015, 03:20 PM
  5. Replies: 0
    Last Post: 10-19-2015, 03:03 PM
