1. AC Question's Avatar
    I have a ZTE with Tracfone Wireless. I accidentally put it in the washing machine, for a full cycle, and didn't notice until afterwards.
    When I pulled my phone out, it was off, the screen had water damage, and it was continuously vibrating. The phone was on when it went in the washing machine, but now it will do nothing but vibrate.
    I removed the battery immediately. Any time I put the battery towards the direction it is intended to fit, aligning the positive charge with its corresponding prongs (? forgive me, I don't know much about this type of technology) the vibration continues.
    I thought it may have been an issue with the battery, so I tried plugging my phone in without the battery, and the vibration continued then too.
    Is this a short-circuit? There is no SIM card and everything is stored internally. Should I consider everything on my phone to be gone forever?
    10-20-2015 02:44 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! It's dead. Devices don't survive that kind of water damage. Your data is unfortunately gone, except for any Google app data that normally syncs automatically with your Google account in the cloud. Photos are gone as well, unless you turned on Google Photos Auto Backup.
    Laura Knotek likes this.
    10-20-2015 03:35 PM
  1. Replies: 1
    Last Post: 10-20-2015, 03:39 PM
  2. How can you tell if your Galaxy Note 4 has water damage?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 10-20-2015, 02:37 PM
  3. how can you tell if your galaxy note 4 has water damage?
  4. Replies: 0
    Last Post: 10-20-2015, 07:33 AM
  5. Is it possible to fully reinstall the entire Android system?
    By AC Question in forum Android OS Discussion & Help
    Last Post: 10-20-2015, 02:50 AM
