A
AC Question
I purchased an Extended 3000mAh 11.1Wh 3.7v battery for my Samsung Galaxy S3 phone after my standard battery needed replaced. The new extended battery is considerably "fatter" than the standard battery. 2 days later, the charging port on the phone went out. I then bought a wireless charger receiver module and charging pad BUT the receiver module connecters will not reach the 2 connection points inside the phone. I have searched endlessly, to no avail, for a wireless receiver module specifically designed for the 3000mAh battery. Is there someway I can add "something" to make what I have work? I am desperate. Thank you for any help anyone can give.
