1. AC Question's Avatar
    Is this a issue with the battery. Is my battery fine? I didnt use it for almost 5 hours my phone's battery had increased to 12%. How did this happen?
    10-22-2015 10:06 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! I assume it wasn't plugged in anywhere, correct?
    Has the battery otherwise been behaving oddly? It might just be an issue with the battery monitor software. You can try calibrating it by charging up to 100%, using it until it shuts off, and then repeating the cycle about 3 times. Then see if the battery stats make more sense.
    10-22-2015 11:53 AM
  1. Why is there so much data in Miscellaneous Files?
    Last Post: 10-29-2015, 04:38 PM
  2. Replies: 3
    Last Post: 10-27-2015, 11:14 AM
  3. Why is Android OS using 64% of my battery
    Last Post: 10-22-2015, 12:11 PM
  4. How do I turn the flash light on. ( Turbo)
    Last Post: 10-22-2015, 12:03 PM
  5. Replies: 1
    Last Post: 10-22-2015, 09:53 AM
