A
AC Question
Hi, my shiny new 6P should be arriving next week and I'm struggling with the decision of which car mount to purchase. Here's my requirements (I'm awkward):
1) No vent mounts, blasting hot air on my device doesn't sound wise
2) No magnetic mounts, I actually make use of the compass
3) No windscreen suction mounts as I get terrible condensation and they just drop off
4) No cigarette lighter or cd slot mounts as I have neither
5) No jaws protruding way in front of the device obstructing access (minimal protrusion is okay)
6) Charge port, audio port, volume and power all accessible
7) Proclip not an option as their mounts for my car are all in useless low down positions
8) My dashboard is fairly curved although I wouldn't object to a screw or two if needs be.
Told you I was awkward
