1. AC Question's Avatar
    Unfortunately it seems that the usb-c cable for the supplied wall charger is hard wired into the power block. I've ordered a separate usb-c to usb-a cable but can someone recommend a suitable power block that can take a usb-a cable and still provide the 3A for fast charging so that I can use it as a spare charger? The only power blocks (i.e. the bit that plugs into the mains socket) that I can find offer 1.0A or 2.1A.
    10-22-2015 03:14 PM
  1. Replies: 1
    Last Post: 10-26-2015, 02:56 PM
  2. How do I update the new towers
    Last Post: 10-22-2015, 03:12 PM
  3. did i do any physical hardware damage to my s6?
    By musician3399 in forum Samsung Galaxy S6
    Last Post: 10-22-2015, 02:50 PM
  4. How do you back up S6 and restore to multiple points in time?
    Last Post: 10-22-2015, 02:17 PM
  5. Replies: 1
    Last Post: 10-22-2015, 01:30 PM
