1. AC Question's Avatar
    I have tried connecting my Edge+ to gear s2 watch, but the message i get is "check if your phone is compatible and if the Samsung galaxy app needs to be updated, then try again". How can i get it to connect?
    I have checked for the latest version of gear manager by going to apps.samsung.com/gear and i see that i have the latest version installed. Also i purchased the watch from korea and the default language seems to be Korean.
    10-24-2015 11:51 AM
  2. rakmi's Avatar
    Hi, I also have same problem.. i got my gear s2 in korea and it wont connect with my s6. Did you find out the problem?
    10-29-2015 07:29 AM
  3. ibsheeen's Avatar
    same problem here... found any solution???
    01-05-2016 05:23 PM
  4. jaynz's Avatar
    Hi I also had the same problem, however I had been using my gear s2 with my galaxy s5, after many hours of reading all your forums, and researching the samsung site I accidentally found my solution, I had to factory reset the gear s2;
    Press home button , then settings, gear info, reset gear, factory reset
    And then once it restarted it pared not a problem with my new s6 edge +, so the issue could be that the watch has previously been paired with another device and needs to be reset.
    I hope this helps?
    02-13-2016 03:29 AM
  5. jlt14500's Avatar
    I was having the same problem. This time I turned off bluetooth on s6 and installed gear. Reset the watch. Turned WiFi on the s6. When gear said turn on Bluetooth I hit cancel the the gear app installed. Funny that. Then app turned on Bluetooth automatically , the s6 and s2 watch paired and all is good. Hope this helps.
    04-09-2016 09:16 AM
  1. Clarification on using NFC readers will SPay.
    By Mr_Bugman in forum Samsung Pay
    Last Post: 10-29-2015, 07:36 AM
  2. How to update china tablet to kitkat/lollipop
    By JesHyoDaJi in forum Ask a Question
    Last Post: 10-24-2015, 11:09 AM
  3. Replies: 0
    Last Post: 10-24-2015, 11:03 AM
  4. Galaxy S6 cannot make or receive calls over wifi
    Last Post: 10-24-2015, 11:00 AM
  5. Samsung Galaxy S5 VS Samsung Galaxy S6 Questions
    By swordfish48721 in forum Ask a Question
    Last Post: 10-24-2015, 10:59 AM
