1. Echo86's Avatar
    Hey everyone
    Just bought a Sony SmartBand SWR10 which I was told at the store would work perfectly with my Samsung S6 Edge Phone.....
    Set up the app and downloaded the 3 things I needed......
    Signed in with my Playstation account and did all the age, weight etc stuff and it seemed to connect fine.
    Now problem is the lifelog thing isn't logging the stuff I do.
    I have taken 5 pictures and the log is showing 0
    it records my steps sort of..... which is kinda only when it wants to.
    It is vibrating when I get a call or text but thats about it....
    I have gone through all the settings I can find but nothing seems to help
    10-25-2015 12:16 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! I'm not too familiar with that app--but if you go into its settings, can you tell us if the Logger setting is turned on? See this video.
    10-25-2015 08:13 PM
  1. History on edge??
    By broken girl in forum Samsung Galaxy S6 edge
    Last Post: 11-03-2015, 03:30 PM
  2. Replies: 1
    Last Post: 10-25-2015, 08:38 PM
  3. Can't connect to mobile data on samsung s5
    Last Post: 10-25-2015, 08:36 PM
  4. Why doesn't Moves work on my Samsung Note 5?
    Last Post: 10-25-2015, 12:06 PM
