1. AC Question's Avatar
    Hey all!
    I'm having a problem with my LG G2's wifi detection. When I pull down my notification bar, I see that my wifi is on. However, when I go to the actual wifi menu, it still says "Turn Wifi on in the upper right corner to see available devices" and that the wifi switch is off. When i turn the wifi switch on, my phone won't search for any networks! Help! Thanks in advanced.
    10-26-2015 08:56 PM
  1. Replies: 2
    Last Post: 10-27-2015, 10:33 AM
  2. what to do if i can't connect to wifi showing
    Last Post: 10-27-2015, 04:47 AM
  3. what to do if i can't connect to wifi showing
  4. Still have echo with turning on the noise reductions?
    Last Post: 10-27-2015, 02:13 AM
  5. Galaxy S5 won't connect to mobile data after turning off wifi
    Last Post: 10-26-2015, 08:17 PM
