1. AC Question's Avatar
    I just bought this Samsung Galaxy 4 Tablet Model #SM-T530NU and when you try to insert the SD Card it doesn't "click" and lock the SD Card in place it just pops back out as soon as you let go of it. Had it checked by IT guys the card is fine it is being inserted correctly it just won't fasten it inside the slot. They say that my only option is to mail it to Samsung for warranty repair which can take 3 to 4 weeks!!! I just got this tablet to replace a Horrible Lenovo Lemon that gave me 2 weeks total of usage in the 7 months between mailing it in 3 different times trip after trip! I can't go without it again I need it for work!
    10-27-2015 04:45 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! The spring lock must be broken or defective. Since it's under warranty, sending it back to Samsung is probably your best bet. If you can't wait, you could bring it to a local repair shop and see how much it costs to replace--but that will void your warranty.
    10-27-2015 05:46 PM
  1. Replies: 2
    Last Post: 10-27-2015, 05:50 PM
  2. Replies: 1
    Last Post: 10-27-2015, 05:46 PM
  3. does a Galaxy 4 need a sim card just to turn on?
    Last Post: 10-27-2015, 05:00 PM
  4. can i get a copy of my order for the nexus 69
    Last Post: 10-27-2015, 04:58 PM
  5. How can I get root permission on my T-Mobile Nexus 6?
    By AC Question in forum Google Nexus 6
    Last Post: 10-27-2015, 04:40 PM
