1. AC Question's Avatar
    The galaxy S6 , It is not responding to 1 tap so I can't open anything or turn it off to reset. Turning it off requires a tap even and they made it nearly impossible to remove the battery and reset the phone that way. I gotta sit here and wait for phone to die is ridiculous
    Older phones I have had the same problem and it is an easy fix since there are several was to turn off and reset the phone.
    10-27-2015 06:11 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! You can force a shutdown by pressing and holding Power and Vol Down for around 15-20 seconds.
    10-28-2015 03:05 AM
  1. On battery drain, chargers and extra batteries.
    By droidntn in forum Samsung Galaxy Note 4
    Last Post: 10-31-2015, 09:22 PM
  2. How can I delete the Outlook app from my Note 3??
    By AC Question in forum Samsung Galaxy Note 3
    Last Post: 10-28-2015, 03:06 AM
  3. how do i get my phone ringtones off default setting
    Last Post: 10-27-2015, 06:21 PM
