1. Zierull Nroll's Avatar
    I am using Android 4.2.1 - Jelly bean - It automatically somehow has installed monkey test and time service. and after repetitive un-installation, it again gets automatically installed and now it is popping other msgs like- 1. unfortunately pro has stopped, 2. unfortunately measure has stopped,3. unfortunately adobe has stopped !! i am fed-up of such msgs.. and automatically a few programs are starting to run n due to this, my phone is getting hanged or heating up.
    I have tried every antivirus but all in vain !! I have many a personal data which cannot be compromised at all. PLEASE HELP Javier !!
    10-28-2015 05:47 AM
  2. Javier P's Avatar
    Hi Zierull, welcome as a new member!
    Have you already tried all the possible fixes in this thread and in the links included?
    how do i fix unfortunately measure has stopped in my phone
    Some people managed to remove those apps completely but for others even a factory reset didn't work.
    Which device do you have? If nothing works you'll need to flash your ROM back.
    10-28-2015 07:20 AM
  1. How can I root my TMO sm-n910t3 Note 4?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 10-29-2015, 11:04 PM
  2. Moto Maker. How is your phone delivered to you?
    Last Post: 10-28-2015, 04:43 AM
  3. How to redeem a code
    Last Post: 10-28-2015, 04:36 AM
  4. Want to Replace Razr Maxx with phone that can mirror video
    Last Post: 10-28-2015, 04:07 AM
