1. outlaws00n's Avatar
    So my phone displays that it's 100% charged. However, if I unplug the phone then it will power off and attempt to power back on (displays note 4 screen then screen turns back). I figured removing the battery a few seconds would address the issue but that doesn't help either. Needless to say, the phone says it's fully charge but if I remove it from the charger...same cycle. Any suggestions please?
    10-30-2015 06:56 PM
  2. Raptor007's Avatar
    Sounds like a battery issue and while its plugged in its getting direct power. Do you know anyone else with a Note 4 you can test their battery on your phone?
    hamad.khan52 likes this.
    10-30-2015 07:54 PM
  3. outlaws00n's Avatar
    Yes and I plan to do swap them today. I'll keep updated.
    10-31-2015 11:03 AM
  1. How to get rid of possible virus?
    Last Post: 02-23-2016, 06:02 PM
  2. Replies: 1
    Last Post: 10-30-2015, 11:36 PM
  3. I have just picked up a battery virus on my s5
    Last Post: 10-30-2015, 07:39 PM
  4. Which smartphone is better Samsung Galaxy S6 Edge or Nexus 6P?
    Last Post: 10-30-2015, 04:27 PM
