The phone is slow going from the text screen to the home screen, or if a call comes in it seems to pause until I can answer, hence removing the battery to get the phone back to normal.
I do not have many apps on the phone and I have tried removing the ones I have to see if it helps but no change, one thing I have on my phone is the LG cover, I am going to remove that to see if that helps.
Maybe wondering if the lack of onboard RAM could be the problem, I really like the LG phone just need it running normal and not removing the battery every 5 days.
