1. AC Question's Avatar
    My phone is Oppo R831k Neo3
    11-02-2015 08:49 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does that persist after a reboot? How about Safe Mode? On most Android devices, while powered on, press and hold Power until the Power Off menu appears. Press and hold the Power Off selection until the Safe Mode prompt appears. Tap OK.
    If the problem disappears in Safe Mode, then something you installed is causing the problem. You may have to uninstall apps one by one until the problem disappears. If the problem persists in Safe Mode, then it's more likely to be a hardware or firmware problem.
    11-03-2015 06:10 PM
  3. Brendon Byod Urie's Avatar
    Thanks bro,its work for me went I uninstall some of the apps in my phone just now..thnkz alot
    B. Diddy likes this.
    11-06-2015 09:28 PM
  4. Jinlax Basher's Avatar
    hey after i reset my galaxy tab 3 it still pops out i dont know how to fix this pls help me . tnx
    11-07-2015 05:14 AM
  5. faisal ahamed sagor's Avatar
    prosses Android problem
    01-31-2017 02:29 PM
  1. My Hot Keys: how can we get this Note 4 feature on our Note 5?
    By Sammuel1973 in forum Samsung Galaxy Note 5
    Last Post: 08-22-2016, 05:20 PM
  2. Replies: 4
    Last Post: 11-06-2015, 12:32 AM
  3. Replies: 1
    Last Post: 11-03-2015, 06:11 PM
  4. Why is my downloads nit letting me install things?!?!?
    Last Post: 11-02-2015, 10:11 PM
  5. Replies: 1
    Last Post: 11-02-2015, 09:35 PM
