1. AC Question's Avatar
    my lg Optims Fuel phone will not charge , will not turn off. will only show a system error on the screen . That is all it will do
    11-03-2015 07:54 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! What does the system error say or look like? If the screen is frozen on it, remove the battery for 10 seconds, then reinsert it and try powering back on again. If you keep getting the same error, then either the firmware is corrupt or the motherboard has failed. It'll be hard to fix either by yourself. Bring it to a repair shop.
    11-04-2015 12:43 AM
  1. Will my Moto G 3rd Generation get Marshmallow?
    By Casual Android in forum Android 6.0 Marshmallow
    Last Post: 11-09-2015, 03:12 AM
  2. Replies: 1
    Last Post: 11-04-2015, 01:35 AM
  3. How can I fix: unfortunately, the process android.process.acore has stopped?
    By AC Question in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 11-04-2015, 01:32 AM
  4. Secondary Screen
    By momo662 in forum LG V10
    Last Post: 11-03-2015, 08:21 PM
  5. Why does my LG Optimus Fuel screen say system error?
    Last Post: 11-03-2015, 07:51 PM
