1. AC Question's Avatar
    In a Samsung SIII I9300 Duo phone with 2100 maH battery, will a 2600 maH battery fit ?
    I mean is the battery compartment adequate for 2600 ?
    11-04-2015 09:00 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! It depends on how they made the battery. Manufacturers can pack the battery cells more densely to achieve a higher mAh, while keeping the battery the same size. Is the battery designed for that specific phone?
    11-05-2015 02:33 AM
  1. Replies: 11
    Last Post: 11-05-2015, 02:07 PM
  2. Samsung Galaxay S4 will vibrate but not ring
    Last Post: 11-05-2015, 02:44 AM
  3. Replies: 0
    Last Post: 11-04-2015, 07:59 PM
  4. Replies: 0
    Last Post: 11-04-2015, 07:42 PM
  5. Does the Google Nexus 5x work with Red Pocket CDMA?
    Last Post: 11-04-2015, 07:28 PM
