1. AC Question's Avatar
    So i rooted my friend's tablet because it had some viruses that made into system files. I deleted some of them. While picking them i also deleted systemui which killed the tablet. Its just stuck at the boot menu. Wipe partition doesnt work, factory reset doesnt work. I can probably find the systemui.apk file from my other friends. Is there a way i can place it there ? Like i said it just doesnt open i cant do anything. Im not the kind of person that would do such a stupid thing but rooting this tablet was a pain in the *** cause it had viruses + it was given from government so it had blocked usb access blocked apk installs etc. So i really really need help if you guys have no idea what to do i can maybe send it to warranty but its pretty dangerous because i rooted it so they might not take it back. Any help would be apprecieated i can probably do some complicated stuff but explain it as good as possible. Thanks for the help guys.
    11-05-2015 12:27 PM
  2. Kelly Kearns's Avatar
    Welcome to the forums!
    Can't help you with the issues, but if this is a current government tablet, it needs to go right to the IT Dept and certainly doesn't need to be rooted.
    Laura Knotek likes this.
    11-05-2015 12:54 PM
  3. Golfdriver97's Avatar
    Since there is USB restrictions, I'm not sure if there is a way to save the device.
    11-05-2015 01:01 PM
  4. Jaspreet Singh Reehal's Avatar
    Here is a way to repair ur device software if u can't acess anything just turn it off and charge it above 80℅ then download it's stock ROM from google.flash it in ur device and it will be working properly(but data stored in internal storage will be deleted)
    02-04-2017 02:55 AM
  1. Replies: 1
    Last Post: 11-05-2015, 05:14 PM
  2. Replies: 0
    Last Post: 11-05-2015, 12:12 PM
  3. Replies: 1
    Last Post: 11-05-2015, 11:39 AM
  4. Why is everything i type saving on my phone how to delete
    Last Post: 11-05-2015, 11:36 AM
  5. Replies: 1
    Last Post: 11-05-2015, 11:22 AM
