1. AC Question's Avatar
    I have an S6 edge plus and in about half an hr with Wifi on, i lost 3 percent. I looked at GSAM battery monitor, and Wifi-active only accounts for 6%. I was not downloading anything or doing anything. Then you look at app usage and it accounts for 60% of battery loss, in that 60%, android system uses 27.6%, kernal(android OS) uses 13.6%, and system UI 4.2%. I barely lose any battery when I have Wifi off. My verdict is that one or more of the packages within Android system is active when wifi is on, therefore casuing the drain. I have Samsung Package Disbler which i can use to block packages if I can find which one. Does anyone know which one of the package(s) actitvate when wifi is on?
    11-08-2015 01:41 PM
  1. Mdnsd killing battery?
    By martinr85 in forum Android 5.0 Lollipop
    Last Post: 04-22-2017, 01:21 PM
  2. Is it possible to get text from a old phone?
    Last Post: 11-08-2015, 02:39 PM
  3. Can I get contacts search to happen by first name?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 11-08-2015, 01:29 PM
  4. Why cam I unable to update my Android system?
    By AC Question in forum Android 5.0 Lollipop
    Last Post: 11-08-2015, 01:16 PM
  5. Why isn't my Android phone turning on?
    Last Post: 11-08-2015, 01:14 PM
