1. Old preacher's Avatar
    It's a Motorola Droid Maxx. I've had it two and a half years. Battery life has been great until now.
    If I go to settings - apps - running, I can stop some of the apps. If I remember to do that right after I turn the phone on it behaves the way I used to. If I forget the battery runs down in just a few hours even though I'm using the phone hardly at all. Why did this problem suddenly start? What can I do about it?
    11-09-2015 05:35 PM
  2. Rukbat's Avatar
    Which apps. It's possible that one of them is causing the problem, maybe due to a recent update.
    It's also possible that, after 2-1/2 years, the battery is gone.
    11-10-2015 02:06 AM
  3. Old preacher's Avatar
    The app that seems to be causing the most battery drain is Media. If I stop Media after I turn the phone on, battery life is as good as it used to be.
    11-10-2015 04:44 PM
  1. note 5 locking up all of the sudden?
    By canthoine in forum Samsung Galaxy Note 5
    Last Post: 11-13-2015, 08:05 AM
  2. With all the hype given the 6P
    By Ksquared64 in forum Samsung Galaxy S6 edge+
    Last Post: 11-12-2015, 11:35 AM
  3. Replies: 1
    Last Post: 11-10-2015, 02:03 AM
  4. Updated to 5.1.1. Now my phone is malfunctioning.
    By koglin9 in forum Samsung Galaxy Note 4
    Last Post: 11-09-2015, 09:53 PM
  5. Replies: 1
    Last Post: 11-09-2015, 07:02 PM
