1. AC Question's Avatar
    I accidentally dropped my phone in the toilet. No one was using it so it dropped in just plain toilet water. I dried it out and got everything to work fine but now it keeps saying battery is at a low temperature and won't charge. Any ideas?
    11-14-2015 08:05 AM
  2. srkmagnus's Avatar
    Leave the device powered off with the battery removed for a few hours. Try powering back on and see if that helps. If not, then there is water damage to the device which can't be repaired. Instead the device needs to be replaced.
    11-14-2015 09:16 AM
  3. Ivan Jenic's Avatar
    Also try to vacuum it with a vacuum cleaner, but don't use hair dryer, because it may damage it.
    11-14-2015 02:50 PM
  1. Why won't apps install to SD card Samsung tablet?
    By AC Question in forum Samsung Galaxy Tab A (8 & 9.7)
    Last Post: 03-19-2016, 09:46 PM
  2. How do you unlock a Verizon Samsung galaxy s5
    Last Post: 11-18-2015, 03:52 PM
  3. On my Samsung Tab, how do I remove a password of a memo?
    Last Post: 11-14-2015, 10:02 AM
  4. Charging Problem on My Samsung Galaxy S3 Neo (GI-i9300I)
    Last Post: 11-14-2015, 09:48 AM
  5. Samsung Galaxy S4 won't save photo correctly
    Last Post: 11-14-2015, 06:54 AM
