1. AC Question's Avatar
    I am being told I don't get phone calls so I tested myself, with phone on the same spot some calls come thru some do not. I started to check if the signal is consistent and what's the level so i learned phone was showing signal between - 103 to - 113 dBm.
    I swap the SIM with another Verizon SIM one and this shows -93 dBm on the VERY same spot. The other phone shows the same -103 to -113 dBm signal strength.
    How could the SIM influence the signal strength?
    Has anybody run into this issue? Is this a verizon issue due to the weak signal?
    Thanks
    11-14-2015 06:26 PM
  2. Raptor007's Avatar
    So you swapped the SIM cards and the new SIM was getting better reception. That one I haven't seen before, but it could be a programming issue with the SIM or the phone wasn't get the right programming itself. Odd none the less, but given its a Nexus phone that Verizon didn't sell directly to you they won't stand behind it or guarantee it.
    11-14-2015 08:35 PM
  1. Did Android Wear 1.4 break Messenger on S2?
    By FitzAusTex in forum Samsung Gear S2
    Last Post: 03-25-2016, 02:47 PM
  2. My yahoo contacts do not sync with my Samsung Galaxy S6 edge
    Last Post: 01-06-2016, 03:40 PM
  3. Cant turn on media sharing
    Last Post: 11-15-2015, 05:11 PM
  4. Replies: 1
    Last Post: 11-15-2015, 05:02 PM
  5. Group messaging S5 not grouping, please help.
    Last Post: 11-14-2015, 05:54 PM
