1. AC Question's Avatar
    I have a Galaxy S5 Bought a new battery and charger but it will not charge or turn on
    11-15-2015 12:33 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! The Downloading screen means you got into Download Mode (which is usually accessed by powering on using the Power, Home, and Vol Down buttons). It's used if want to download a firmware file and install it manually. If you're not actually connected to the computer and actively downloading a file, you can power the phone off, then power on normally.
    I'm not sure if you had to buy a new battery. Use either of your batteries, and let the phone charge on a wall outlet for at least 4-6 hours without disturbing it. Then try powering on again.
    11-15-2015 04:20 PM
  1. Talk and surf at the same time?
    By bloodycape77 in forum Verizon
    Last Post: 11-17-2015, 01:32 PM
  2. how do you add signature to your text messages
    Last Post: 11-15-2015, 04:28 PM
  3. Replies: 4
    Last Post: 11-15-2015, 04:24 AM
  4. Updating an Android Tracfone?
    By Wingsley in forum Ask a Question
    Last Post: 11-15-2015, 12:33 AM
