1. AC Question's Avatar
    I plug my charger in and I get the bolt and does not go past this point but when I switch my phone on it immediately turns off as there is 0% battery, can anyone help or has anyone encountered this and fixed it?
    11-15-2015 10:10 AM
  2. belodion's Avatar
    The charger, USB lead, connector inside the USB port, battery, or something else, may be faulty.
    11-15-2015 11:14 AM
  3. ntheodora95's Avatar
    Try charging other phone with your charger. Even if the other phone shows it's charging wait for a while and observe: is it charging normally? (If the charging icon shows but it doesn't seem to increase battery percentage for a while then maybe it's your charger).
    However if you have made sure your charger works fine, another thing you can do is use another WORKING charger--see if your phone charges. If it still doesn't then maybe either the charging port or your battery is the issue.
    11-15-2015 03:38 PM
  1. Replies: 1
    Last Post: 11-18-2015, 02:25 PM
  2. Replies: 1
    Last Post: 11-15-2015, 03:37 PM
  3. Samsung galaxy note 4 screen
    By Tyler7411 in forum Displays
    Last Post: 11-15-2015, 09:58 AM
