1. larry1076's Avatar
    If you're battery is getting low and you want to conserve energy as much as possible, and you have a choice of using data either on your 3g/4g network or connecting to a WiFi network, what should you do?
    11-16-2015 07:37 PM
  2. christian shook's Avatar
    Based off of what I've seen cellular gives a better battery life as long as WiFi is off for some reason I get about an hour to three hours more on cellular also some times a connection Will be lost with WiFi so it searching tends to drain it which I noticed on my iPhone but on I now have a droid turbo and cellular is still the way to go when it comes to battery life
    11-16-2015 09:51 PM
  1. Replies: 1
    Last Post: 11-17-2015, 04:56 PM
  2. Can I use a Sprint Samsung S4 on the T-Mobile network?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 11-17-2015, 04:53 PM
  3. My Galaxy S6 is locked and won't power down, what can I do ?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 11-17-2015, 04:49 PM
  4. Why wont rca tablet connect to wifi
    Last Post: 11-16-2015, 08:35 PM
  5. Replies: 1
    Last Post: 11-16-2015, 07:50 PM
