1. XxVenatorxX's Avatar
    My ZTE X max + head phone jack doesn't seam to work. When I use my ear buds it will pause and play my music unexpectedly as well as lower the volume all the way or turn it all the way up.
    11-17-2015 12:13 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Did the earbuds come with the phone, or are they some other brand? If the latter, do you know if they were "Made for iPhone"? If so, there might be some subtle differences in the configuration of the plug that can cause incompatibilities on non-iPhone devices.
    11-17-2015 01:57 AM
  3. XxVenatorxX's Avatar
    No they didn't come with the phone. They are skull Candy's.
    11-17-2015 08:57 AM
  4. B. Diddy's Avatar
    Try other headphones (that aren't specifically Made for iPhone), and see if the problem persists.
    11-17-2015 10:45 AM
  1. Photoshop App Help!?
    By Tommy Bayshore in forum Samsung Galaxy Note 5
    Last Post: 11-18-2015, 11:44 PM
  2. How do I change the widgets lock screen on my Nexus 6 phone?
    By AC Question in forum Google Nexus 6
    Last Post: 11-17-2015, 02:00 AM
  3. Help! Fast charging on my Zenfone 2 isn't working.
    By Tiggyyo123 in forum Ask a Question
    Last Post: 11-17-2015, 01:56 AM
  4. Suggest me Best Smart phone under 25000 Rs or 400$......
    Last Post: 11-17-2015, 12:02 AM
  5. My power saving mode won't work
    Last Post: 11-16-2015, 11:09 PM
