Samsung SM-N9005 NOTE 3 says charging but battery continues to drain? Cant connect to PC aswell
A
AC Question
hi guys,
my note 3 isnt charging anymore... battery continues to drain even when plugged in
ive tried different usb wires (2.0 and 3.0) and usb plugs - still no luck
i just replaced the charging block today and the issue is still there..
its had water damage recently (last sunday) as i climbed mount snowdon but i was able to revive the phone using isopropyl and a tooothbrush to clean the motherboard.. everything else works perfectly ..
im having to use an external battery charger at the moment but its annoying!!
any help would be appreciated!!! :)
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,533
4,668
113
Welcome to Android Central! The water damage may have affected the microUSB port. When you're plugged into a wall outlet, does it say Charging (AC) or Charging (USB) in the Settings>Battery menu?
