A
AC Question
hi guys,
my note 3 isnt charging anymore... battery continues to drain even when plugged in
ive tried different usb wires (2.0 and 3.0) and usb plugs - still no luck
i just replaced the charging block today and the issue is still there..
its had water damage recently (last sunday) as i climbed mount snowdon but i was able to revive the phone using isopropyl and a tooothbrush to clean the motherboard.. everything else works perfectly ..
im having to use an external battery charger at the moment but its annoying!!
any help would be appreciated!!!
