1. AC Question's Avatar
    hi guys,
    my note 3 isnt charging anymore... battery continues to drain even when plugged in
    ive tried different usb wires (2.0 and 3.0) and usb plugs - still no luck
    i just replaced the charging block today and the issue is still there..
    its had water damage recently (last sunday) as i climbed mount snowdon but i was able to revive the phone using isopropyl and a tooothbrush to clean the motherboard.. everything else works perfectly ..
    im having to use an external battery charger at the moment but its annoying!!
    any help would be appreciated!!!
    11-21-2015 10:19 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! The water damage may have affected the microUSB port. When you're plugged into a wall outlet, does it say Charging (AC) or Charging (USB) in the Settings>Battery menu?
    11-21-2015 02:24 PM
  1. Replies: 1
    Last Post: 11-21-2015, 02:35 PM
  2. How do you word wrap on the Note 5?
    Last Post: 11-21-2015, 10:05 AM
  3. Is it possible to update to lollipop and if not, kitkat?
    By mawil1013 in forum T-Mobile Samsung Exhibit 2 4G
    Last Post: 11-21-2015, 09:56 AM
  4. Replies: 0
    Last Post: 11-21-2015, 09:40 AM
  5. Lollipop on Samsung SGH-T679 (T-Mobile)?
    By mawil1013 in forum General News & Discussion
    Last Post: 11-21-2015, 09:39 AM
