1. AC Question's Avatar
    My picture has zoomed in and is no longer long enough. I have tried to replace the picture but it does the same thing. How do I fix this?
    11-23-2015 04:01 PM
  2. Javier P's Avatar
    Hi, welcome to the forums! What phone do you have? Which method are you using to set the wallpaper? From your gallery, some specific app or after long press on your homescreen?
    11-23-2015 04:16 PM
  3. gouge28's Avatar
    I have a LG g3. I downloaded a picture from my gallery.
    11-23-2015 05:21 PM
  4. Javier P's Avatar
    Thanks for registering! Does the same happen if you long press on the home screen and then tap on wallpaper to set a new one up?
    11-23-2015 05:27 PM
  5. gouge28's Avatar
    Yes
    11-23-2015 06:00 PM
  1. Why does my Android turn off Screen lock unless on airplane mode?
    By AC Question in forum Samsung Captivate Glide
    Last Post: 11-29-2015, 12:19 PM
  2. Replies: 2
    Last Post: 11-25-2015, 09:40 AM
  3. Replies: 2
    Last Post: 11-24-2015, 05:26 AM
  4. Replies: 3
    Last Post: 11-23-2015, 07:51 PM
  5. My screen is off / black but phone is functioning, what can I do ?
    By zaakzus in forum Samsung Galaxy S6 edge
    Last Post: 11-23-2015, 06:25 PM
