1. Recovery Question's Avatar
    The Acer tablet is a model A-1 810. Android 4.4.2 kitkat.How to get back to to reboot after
    3+ hours" erasing" ?
    11-23-2015 05:55 PM
  2. AlphaTango414's Avatar
    Try holding power and vol down for 15-30 seconds. If not after the battery runs down and powers down, charge and try to boot into the device.
    B. Diddy likes this.
    11-23-2015 06:52 PM
  3. NNyarko23's Avatar
    I am having the same issue. It had been shutting down randomly. None of my apps would work or cause it to crash so I decided to reset it and wipe everything. Now it is stuck on that annoying robot erasing but the progress bar has not moved. I have tried shutting it down, holding down power and volume and it just reboots back to the same damn screen. I am throwing it against the wall and Android can suck it! Apparently I purchased a POS.
    03-04-2016 09:49 AM
  1. Replies: 2
    Last Post: 10-05-2016, 12:57 PM
  2. Why is my phone stuck in emergence mode?
    Last Post: 11-23-2015, 07:16 PM
  3. How do you move your files from inernal storage an SD card on ZTE Andriod?
    By AC Question in forum Other ZTE Android Phones
    Last Post: 11-23-2015, 07:06 PM
  4. Note 5 is asking for a passcode_stuck on emergency call, what can I do?
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 11-23-2015, 06:58 PM
  5. Replies: 0
    Last Post: 11-23-2015, 05:47 PM
