1. AC Question's Avatar
    I just bought a couple of wireless chargers and am concerned that they will reduce the usefull life of my phone.
    11-25-2015 03:10 PM
  2. LeoRex's Avatar
    Wireless charging isn't hard in your battery... From the battery's perspective, it's getting charged and doesn't care how that happens really.
    Now, if the wireless charger ends up generating way too much heat, that's another issue. But it shouldn't do that in the first place.
    Rukbat and Laura Knotek like this.
    11-25-2015 09:29 PM
  3. Rukbat's Avatar
    Feel the charging plate after about 30 minute of charging. If it's more than warm, it's probably raising the battery temperature. How much? There are apps that will tell you. Run the app, put the phone on the charger and see how much it heats up (compared to charging it with the regular charger). A few degrees more is okay - 20 degrees isn't, and I'd return the charger.
    Laura Knotek likes this.
    11-26-2015 12:13 AM
  1. What is wrong with my battery?
    By Fatimah Mazafar in forum Ask a Question
    Last Post: 12-01-2015, 03:20 AM
  2. iPhone 6s front camera selfie capabilities on Android?
    By vertigoq3 in forum Android Apps
    Last Post: 11-26-2015, 12:28 AM
  3. Replies: 1
    Last Post: 11-26-2015, 12:15 AM
  4. What is wrong with my battery?
    By AC Question in forum Batteries
    Last Post: 11-26-2015, 12:04 AM
  5. Why won't my Samsung Galaxy Note 2 turn on?
    By AC Question in forum Samsung Galaxy Note 2
    Last Post: 11-25-2015, 03:09 PM
