1. RandomGuy1305's Avatar
    So im having problems with my Galaxy S5 running 5.0 Lollipop, its not enabling the lock screen after I Have the lock set to the Fingerprint
    Lock and sometimes it will enable the lock screen and sometimes it wont but it seems like most of the time it doesnt. When it doesnt it has a lock in the bottom right corner of the screen that you have to swipe to enable the lock but without enabling it you are able to get in the phone by just swypeing the screen. Of course if someone was trying to get in my phone all they would have to do is swype the screen if the lock wasnt enabled automatically. Ill attach some screenshots of it enabled and not enabled. I was just wondering if
    This was just a bug or maybe if theres a setting to make it where the screen aways locks. Sorry if im kinda rambling on about it. 😜
    Attached Thumbnails Lock screen problems GS5-screenshot_2015-12-04-16-55-15.jpg
    12-04-2015 04:14 PM
  2. belodion's Avatar
    Welcome.
    Have you tried Safe Mode, to test whether a third-party app is causing the trouble?
    RandomGuy1305 likes this.
    12-04-2015 05:34 PM
  3. RandomGuy1305's Avatar
    Ok, I just tried booting in safe mode and the lock screen worked perfectly so I pretty sure its a 3rd party app that is causing the issue.
    (Note: I do have a Pebble Connected and have several apps for the Pebble and idk if the apps may be interfering with the lock screen but I have a strong feeling that thats whats causing the issue.)
    12-04-2015 06:11 PM
  1. Major problems with BLU Life One Android 5 Lollipop update
    By TangoSmiles in forum Blu Android Phones
    Last Post: 07-20-2016, 04:27 PM
  2. EXTREME battery problems
    By Tafa83 in forum Samsung Galaxy S4 Active
    Last Post: 12-10-2015, 10:57 AM
  3. Can you recommend a glass screen protector?
    By DenverRalphy in forum Samsung Galaxy Note 5
    Last Post: 12-08-2015, 09:12 AM
  4. Replies: 3
    Last Post: 12-07-2015, 03:59 AM
  5. How do I put time on front screen of the phone?
    By AC Question in forum Displays
    Last Post: 12-04-2015, 02:03 PM
